HELP! Any Tire Warranty?
Old Feb 22, 2004 | 02:07 PM
BIGAPPLEVIP's Avatar
Well basically i was driving around last night "doing about 40 " when the car started to pull to one side. i stopped the car and pulled over when i looked at the tire i noticed a long cut that went around half the tire on the side wall. so now im like what did i hit so when i took the tire off to put on the spare i noticed the same type of tire damage on the opposite side of the tire. now my question is (A) is there any type of warranty on the tire and (B) who is responsible? is it Infiniti OR Michelin
Old Feb 22, 2004 | 04:55 PM
redwillow's Avatar
20 Year Member
Re: HELP! Any Tire Warranty?
yeah, look in your manual. Mine says to see a local authorized michelin dealer for tire warranty claims. Michelin does warranty the tires for manufacturer defects. You might try taking the tire to an authorized michelin tire dealer. If they determine it was defective they will probably pro rate the price of a new tire for you.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Feb 22, 2004 | 08:50 PM
newbie35's Avatar
I have a gash in my RSA's. I was unsure if it was driveable because it was about 1" long but all the way down to the tire. I took it to the dealership and they told me that it was not covered under warranty and wanted $200 for a new tire and labor. The mechanic took a look at it and said it was driveable.
2003 IP Coupe. Non-Navi. 19" DTM Kreuz 7. V-Kool & Metallic Tint.
Old Feb 26, 2004 | 03:51 PM
ryoken's Avatar
This is no Road Hazard coverage that comes with the oem tires. If the cut was cause by hitting/running over some external object, then you get to buy a new tire. Sorry.
Old Feb 26, 2004 | 04:01 PM
tmoney's Avatar
Keep an eye on this one guys. When I had my 97 Eclipse Spyder, it had the same problem. Turns out it was an issue with the tight suspension, and the low profile stock tires and it was a known issue to Mitsubishi. But they never did anything about it, never fixed it or offered to do anything about it. Just said it was due to the suspension/tires and that's the way it was. Never did cause any problems, but you could see obvious cracking going on on the sidewall of the tires.
-T
Old Feb 26, 2004 | 06:59 PM
thanks got a new tire from Infiniti. but now when i get the time i got to try and get a new 1 under warranty so i kept the old tire
Old May 21, 2004 | 11:38 AM
nate1749's Avatar
the dealer sells tire and wheel insurance for $500. If you get a nail, etc. you'll get a new tire or if your rim bends (pothole) you'll get a new rim. I never buy insurance like this, but I've had 2 flat tires this year already so I picked it up... I think there's a $50 deductible.
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
