Biggest Tire Size On OEM 19's
Originally Posted by Klubbheads
U are aware that with bone stock tires and rims the speedo and tach becomes very inaccurate at high speeds right? I dont see what the big deal is about ur speedo not showing the right speed.
5% difference at 60mph means you are off 3mph already, thats not even high speeds. Unless you drive around at 120+mph a majority of the time, I don't see the point of your comment. You are also putting 500 additional miles on your odometer for every 10000 miles you travel. But if its worth it for you, great.
I just would not drive the car with tires that look like they belong to the truck. If it had to mess up the speedo a little bit i would not mind at all. That is why everyone is different.
Not really, I have yet to see anyone going 40 profile tires on their aftermarket 19s and anyone who ran out of thread on their stock 19s they always make a thread like this.
You don't get it, the stock 245/40/19 that you say looks truckish has the same sidewall height as a 275/35/19, so wouldn't that mean it looks like a truck also? Thats the most common aftermarket tire size used here in the rear.
Duuuuuuude...we were discussing tire width on OEM's a few weeks ago!!!
I'm running 265/35 and 245/35.
If you really wanted to, you could probably shoe-horn a 295 or 305 on there, but it would look like $hit.
My 265/35 has a straight sidewall as do the 245's up front.
Have the shop fit a 275/35 and put the car down and see if it bulges out or not.
It does NOT look that way because the width of the tire compliments the height on a 275/35/19. Have u seen both in real life next to each other?
A 245/40/19 on an 8.5 has about the same amount of stretch as a 275/35/19 on a 9.5. I've seen plenty of these setups, and they look the same height. Even stretched the height difference is minimal. Sounds like you are seeing things other than sidewall height
Does 265/35/19 look better on a lowered car compared to 265/40/19? Yes or NO?
^u might be right about the speedo inacuracy and stuff but as far as ABS/VDC goes u are completely wrong about that. I have never had any issues with neither of them with 255/30/19s. VDC (When its on) will only come up when the tires lose grip.
Guys, the choice is between a 265/30/19 and a 265/35/19, stock mine are 35 sidewall's also, i just checked!
possibly a 275 tho.
Originally Posted by 06g35meister
thank you for your input, i really was looking for an answer like yours. If you had the option to take your 265 and put a 275 on the back, would you?
possibly a 275 tho.
possibly a 275 tho.
