Do I have to put RWD wheels on my G?
Old Feb 22, 2004 | 09:44 PM
mrshagzsf's Avatar
I've been searching for Rims online and I noticed that some options are for Rear Wheel Drive (RWD) wheels. Do I have to go with these because the selection is not as good? If not, why is this listed as an option. I didn't see any posts on this so sorry if it's been asked already.
Old Feb 23, 2004 | 12:27 PM
3point5SE_Auto's Avatar
Re: Do I have to put RWD wheels on my G?
use the factory arrangement as a base, then calculate what the differences will do to appearance, rubbing, etc. Make sure the combination of offset, wheel width, bolt pattern, and hub diameter (with or without a hubcentric ring, NO SPACERS if you drive hard) work out to fit within the wheel well.
RWD wheels are typically a negative offset, sedan factory wheels are positive (+45 mm) offset, coupe factory wheels are also positive but a smaller positive. Unless you are running VERY wide tires (like 345 or larger) you will need a positive offset to keep from looking like a hispanic lowrider truck
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
CJay
Aug 1, 2015 03:57 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
