Sorry for another offset question but here goes...
Old Nov 15, 2007 | 02:57 PM
rlwjr1's Avatar
I need to buy some new wheels. I want 18x8.5 up front and 18x9.5 in back. The wheels I found have a 30mm offset for the front and a 38mm offset on the rear.
The 9.5" is also available in a 15mm offset.
The brand is this http://www.enkei.com/RacingSeriesSpecs/RPF1.html
or this http://www.enkei.com/RacingSeriesSpecs/GTC%2001.html
I have a COUPE with Brembos
Old Nov 16, 2007 | 12:19 AM
ZentraediG35's Avatar
Bump it up. I'm getting the GTC01's too and would like some info on those offsets as well.
Old Nov 16, 2007 | 09:39 PM
rlwjr1's Avatar
I decided on a 8.5 up front with a +30 offset and a 10" with the +22 offset. 245/45 and 275/40 are the same diameter as the OE tires so there should be no speed sensor or VDC issues.
Old Nov 16, 2007 | 11:07 PM
redlude97's Avatar
If you can still change it, I would get a 18x9+18 instead, the 18x8.5+30 is going to be super sunken. Your front tire size is wrong also, you want a 245/40/18
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
