Will this offset on a 19" rim fit a coupe?
Old Nov 23, 2007 | 01:46 AM
New2G35c's Avatar
Rim: 19x8 front/ 19x10 rear
Offset: 12mm front/25mm rear
Tires: 235/35 front/275/35 rear
Old Nov 23, 2007 | 01:33 PM
EvolutionGSR's Avatar
Depending on the rim and your car, you might want to check to make sure that front offset will clear any oem brembo or aftermarket BBK caliper.
Old Nov 23, 2007 | 01:47 PM
Alan's Avatar
ehhhh front is iffy....might rub on the outside. as ^ said, it depends on the wheel design too.
Old Nov 23, 2007 | 02:21 PM
New2G35c's Avatar
Mine is a non-brembo. These are the rims: RO_JA Formula 5 Forged 2-Piece
Old Nov 23, 2007 | 02:26 PM
Can't say for sure but looks like they'res a good chance of rubbing like alan said.
Old Nov 23, 2007 | 02:49 PM
New2G35c's Avatar
Will that offset make it stick out from the wheel well or will it rub the inside? If it rubs the inside I am guessing a spacer would help, no?
Old Nov 23, 2007 | 03:39 PM
No.
It might rub inside, it might rub fender, it might not rub at all being that its only an 8" wide rim. The spacer will make things worse.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
