SEVAS S22 on G35 Coupe with Brembos wont fit! HELP HELP!
Old Nov 23, 2007 | 01:56 PM
kpark412's Avatar
Hello G35 friends! Im new to this forum and I am looking for help! I bought some Sevas S22 not knowing that I purchased the wrong offset. The rims are hitting the brembos. Does anyone know what size spacers I need to fit the brembos or if you know how the mm sizing works? Thanks!
Rim Width: 10J Tire Width: 235
Rim Diameter (inches): 20 Aspect Ratio: 30
Offset: 40
Number of Bolts: 5
Bolt Pattern: 5 x 4.50 or 5 x 114.3
Ken
Old Nov 24, 2007 | 02:04 PM
kpark412's Avatar
bump!
Old Nov 24, 2007 | 02:26 PM
Mmagic76's Avatar
Try posting in the Coupe forum, this is the for sale section. I'm not 100% sure but i think you need 10-15mm spacer at least to bring it out.
Old Nov 24, 2007 | 03:19 PM
apt2189's Avatar
where did you purchase them from?
apt2189
Old Nov 24, 2007 | 03:28 PM
CrazyRuskie's Avatar
buy 15mm spacers & you should be right
Old Nov 30, 2007 | 03:45 PM
kpark412's Avatar
Sorry I was not aware that this was the forsale section. I will try out 10 and see what works from there. Any recomendation on what brand spacer I should use? I got this off ebay used with tires.
Old Nov 30, 2007 | 03:46 PM
Get 15mm for the rear, what size front wheels do you have? if they're 9" fronts get the 15mm for the front too.
Old Dec 1, 2007 | 03:20 AM
MightyG35's Avatar
i think thats a sedan off set.. well thats what I have on my sedan with the same wheels.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
