245/50r17 fit oem sedan 17 wheels?
Old Feb 28, 2004 | 01:11 AM
tedtf's Avatar
Will 245/50/17 tires fit on the oem 17x7 sedan sport wheels? Is this too wide a tire for that rim?
2003 Brilliant Silver Sedan 6MT
Premium & Winter
Old Feb 28, 2004 | 01:41 AM
ryoken's Avatar
Re: 245/50r17 fit oem sedan 17 wheels?
Check the specs for the tire in question. You'll see that 7" is the minimum rim width, so you're okay.
245/45 requires a 7.5", but we have at least one member running that on the stock rims.
I'd worry more about it rubbing the suspension components in the front than fitting the rim, but it's probably okay.
Not much that I can see in the way of tire choices in that size. What are you planning to run?
Old Feb 28, 2004 | 09:54 AM
tedtf's Avatar
Tirerack has the BF Goodrich Comp TA HR4 on sale right now. Can't find the specs on the tire as it is not made any longer.
Premium & Winter
Old Feb 28, 2004 | 12:02 PM
ryoken's Avatar
What is it you're looking for in a tire? Less noise/more comfortable? Or higher performance? Or just cheaper?
Old Feb 28, 2004 | 12:59 PM
tedtf's Avatar
Better performance, wider track. I was planning on getting Michelin Pilots A/S in 235-50-17, but they are twice the cost og the comp tas.
Premium & Winter
Old Jun 27, 2004 | 07:48 PM
jburnham's Avatar
Did you end up getting the 245/50/17s? If so, how did the ride quality change from the stock tires?
Carribean Blue G35S 5AT Cloth/Sport Package wheels/Invinca-Shield/LOTS of Scotchgard
Old Jun 27, 2004 | 09:21 PM
tedtf's Avatar
I got michelin pilot a/s in 235-50-17. Big difference in handling.
Sport, Premium & Winter
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
teamghost
Jul 28, 2015 04:52 PM
