Will 17x7 +40 work on a 06 coupe (6mt)
Old Dec 17, 2007 | 10:22 PM
intense660's Avatar
Will 17x7 +40 work on a 06 coupe (6mt)??
the reason is, I have a set of rims off my rsx that are 17x7 +40 5x114.3 and the weather just shat up 25 cm of snow a few weeks ago.
thanks guys.
Old Dec 18, 2007 | 01:34 PM
az1anbeethoven's Avatar
the oem acura rims have a smaller hub bore and offset is way too high, so no it will not
Old Dec 18, 2007 | 02:47 PM
Mr Inkredibul's Avatar
I don't think the offset is too high. The stock rims are 7.5 inches wide with a 30 mm offset. So 7 inch wheels with a 40 mm offset would mean the wheels would be positioned a total of 3.65 mm closer to the car. That's nothing.
Old Dec 18, 2007 | 02:50 PM
Here's proof:
http://www.bigwheels.net/?location=w...%20(6%20speed)
Old Dec 18, 2007 | 03:03 PM
redlude97's Avatar
Your math is wrong, the difference is 16mm. It will look goofy, but the offset will work for that width. The problem, as mentioned by az1anbeethoven, is the hub bore being too small on honda/acura applications for our nissan hub bore. The OP is probably better off selling the RSX wheels and purchasing OEM 17" coupe/sedan wheels
Old Dec 18, 2007 | 03:07 PM
Please explain how my math is wrong. You added 6 + 10, but you were suppose to subtract 6 from 10. The stock rim is 12 or so mm WIDER than his Acura rim...that means that you subtract half of 12 (which is 6) and SUBTRACT that from the offset.
Old Dec 18, 2007 | 03:20 PM
redlude97's Avatar
Are we talking outer wheel position or inner wheel clearance? The acura wheels outer position will be 16mm sunken in more from the outer position of the stock wheels, with 4mm less inner clearance. I think we were talking about different things
Old Dec 18, 2007 | 05:03 PM
the offset will fit, but will you want to put a 17x7 +40mm offset on your coupe?
Old Dec 18, 2007 | 05:04 PM
redlude97's Avatar
I have 17x7+45 on my coupe right now
Old Dec 18, 2007 | 05:26 PM
^^i assume the stock sedan wheels...for winter beater??? Please tell me "yes"...
Old Dec 18, 2007 | 05:28 PM
redlude97's Avatar
Yes, I'll be running spacers soon though so it won't be THAT bad, my SSR's are about to get stored for winter as soon as I clean them up
Old Dec 18, 2007 | 05:43 PM
^^good to know, or imma have to ban you mr. staff
Old Dec 18, 2007 | 05:45 PM
redlude97's Avatar
I couldn't pass up the price I got them for, $125/4 in perfect condition without tires, although I've been looking for OEM coupe wheels for 4-5 months with no luck locally
Old Dec 24, 2007 | 09:18 PM
intense660's Avatar
not really its just that i dont wanna spend excess money on WINTER rims.
arora_g35
Apr 16, 2026 02:52 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
newg37
Jul 26, 2015 09:32 AM
Kal Hamm
Jul 24, 2015 08:55 AM
driftsucky
Jul 15, 2015 12:38 PM
