bbk and m45 wheels
Old Dec 30, 2007 | 11:26 AM
JayJay's Avatar
bbk and m45 wheels
Does anyone know if the M45 wheels will clear a bbk? Thanks!
Old Dec 30, 2007 | 12:20 PM
G35Papa's Avatar
Look at Wilwood. I think they make a caliper that isn't as wide as most other BBK. I think the others might be a very tight fit or not work. You'd have to run larger spacers than normal with the M wheels
Old Dec 30, 2007 | 01:30 PM
ttrank's Avatar
Grocery getter
Doubtful without large spacers.
Old Dec 30, 2007 | 07:57 PM
Todd TCE's Avatar
Pretty low clearance as far as BBKs go. About 1"
http://www.wilwood.com/PDF/ds547.pdf
Old Dec 30, 2007 | 11:05 PM
shadyg35's Avatar
with proper spacers will it work. i have an 04 sedan with a rotora 4 piston bbk. i have 20's on now but want to switch to the m45s in my garage. i already have longer studs does anybody have any input?
Old Jan 1, 2008 | 02:19 PM
shadyg35's Avatar
bump
Old Jan 1, 2008 | 03:06 PM
shadyg35's Avatar
come on sedan experts
Old Jan 1, 2008 | 05:30 PM
Sportcoupe35's Avatar
They would probably sit slightly tucked on your sedan without spacers. The likeliness of them fitting without spacers is slim.
But then with large spacers you run into the trouble of have the wheels stick too far out.
Old Jan 6, 2008 | 12:06 AM
shadyg35's Avatar
ttt
Old Jan 6, 2008 | 12:08 AM
FlyingLumpia's Avatar
What size space do you have, best bet is try and see if it fits.
Old Jan 6, 2008 | 12:19 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You'd probably need to run atleast a 15mm spacer, and use a 225/40 tire.
-GP-
Old Jan 10, 2008 | 10:22 PM
shadyg35's Avatar
well right now i just have longer studs sitting here. im gonna order spacers. its just such a pain in the a$$ if i order the wrong ones. im planning on getting turbo and i just want to give them the spacers and studs and have them do it while they do the install. im sure they could find em for me but im spending so much already i would rather just get em online.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
