Flat tire question?
Old Jan 8, 2008 | 10:33 AM
LMSIG35X's Avatar
Flat tire question?
Kind of a strange situation I've had. Just bought a used 05' on Dec. 21st. I took it to an infinity dealer on the 26th to have something checked out. When I left that dealer I had a low tire pressure indicator light on and one of the front tires was low, enough so that you could tell by visual inspection. They took it back in and checked it out put air in it and I was on my way. Then yesterday I had a low tire pressure light come back on. Nothing looked low, so after work I checked the pressure and now one of the rear tires was low, around 21lbs. That night I filled it up and checked all the rest. Everything seemed fine. Now I get up this morning and the same rear tire I filled last night was pretty much flat. Could the tire just not be holding air right? Or does it seem like a nail or something is causing a leak. I didn't waste any time on it this morning as I wanted to get to work, so I just got a ride with my gf. but I'm going to go home at lunch and check it out. Why doesn't Infinity include a full size spare? seems dumb. I don't really want to shell out for a new tire after just purchasing the car 2 weeks ago or so.
Old Jan 8, 2008 | 09:29 PM
oooooooooooooq's Avatar
Inifiniti
Old Jan 9, 2008 | 02:01 AM
bigc's Avatar
Wings Nation
check between the treads for a nail or screw. as long as the hole isn't in the sidewall or close to it any tire shop can patch it for less than $40
Old Jan 9, 2008 | 02:13 AM
UnluckyCharms's Avatar
Originally Posted by oooooooooooooq
Inifiniti
If you're gonna correct his spelling, at least spell it correctly.
Old Jan 9, 2008 | 09:08 PM
wow, i didnt even realize, sorry INFINITI.
what i said was basically, NOT-infiniti
Old Jan 10, 2008 | 08:07 AM
LMSIG35X's Avatar
I didn't even realize I was spelling it wrong noted for future reference.
Tire problem turned out to just be a bad valve stem core.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
GBoy
The Q - Spot
Sep 5, 2015 03:15 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Detailed Image
Jul 29, 2015 08:42 AM
mushu
Jul 15, 2015 03:55 PM
