19" OEM Tires
Old Jan 10, 2008 | 12:40 PM
CalgaryG's Avatar
19" OEM Tires
So just how slippery are these tires in the cold? In Calgary here, we don't really have any snow on the ground/roads, but it has been between -15 and +3 degrees C for the last couple weeks.
The reason I ask - I am planning on getting winter tires when my car arrives, but should have them ready to go beforehand? Or will I be able to survive for a week or two on the summer tires.
I have heard that the rubber isn't the greatest once temperatures drop below freezing...
Old Jan 10, 2008 | 02:41 PM
g35guy86's Avatar
yes summer tires harden up when it gets cold and snow tires are made from a softer rubber.
Old Jan 10, 2008 | 03:22 PM
CalgaryG's Avatar
So am I going to slide out and crash if I'm on those tires at -5 deg. C? Or will I be ok so long as I take it easy? haha
Old Jan 10, 2008 | 03:25 PM
redlude97's Avatar
If there is zero moisture on the ground, you'll probably be okay as long as you decrease your speed, but if its below 40 and wet, you are asking for an accident sooner or later.
Old Feb 13, 2008 | 02:23 PM
I CoUPe's Avatar
Is it THAT dangerous driving in rain with 19"s? Unless you go 10-20 mpg less speed limit.
Old Feb 13, 2008 | 02:30 PM
redlude97's Avatar
When the temps are near freezing, yes.
Old Feb 13, 2008 | 02:36 PM
ttrank's Avatar
Grocery getter
I would replace them with some good all-season tires when you can.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
