20x10 1 piece rim on 03 sedan?
Old Jan 10, 2008 | 11:20 PM
Stolen G's Avatar
is it possible to fit 20x10 1 piece rim on an 03 sedan lowered on tein s-tech without modification?
Old Jan 10, 2008 | 11:58 PM
(>")> G35's Avatar
There aren't many 1 piece wheels that come in 20x10 with a high enough offset to avoid rubbing. You might be able to get away with it since the s-tech drops the car a decent amount, thus could induce a good amount of negative camber.
Old Jan 10, 2008 | 11:59 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You'll need atleast a mild fender roll even with a +50 offset on the wheel, assuming you're going to run the standard 275/30/20 tire.
-GP-
Old Jan 11, 2008 | 01:29 AM
ttrank's Avatar
Grocery getter
But with a fender roll you can fit up to a +40. I've had three sets of 10" rears on my sedan over the last year.
Old Jan 11, 2008 | 01:40 AM
Originally Posted by ttrank
+1
Or a +25 if you wanna stretch the tire and run 2 degrees of negative camber That was just for you Tim, i know how much you loooooove stretched tires and neg. camber!
-GP-
Old Jan 11, 2008 | 02:03 AM
ttrank's Avatar
Grocery getter
I'm still waiting to see you pull off a +25 10" with a 255 and all that camber!
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Jussaku
Aug 4, 2015 12:45 PM
BlackGee35
Jul 31, 2015 11:04 AM
multimut
Canada
Jul 26, 2015 08:43 PM
