Toyo Proxes T1S vs. T1R
Old Jan 21, 2008 | 09:19 PM
G4Sean's Avatar
found a good deal on some Toyo T1S tires, but I can't find any info on them - only on the T1R's. Does anyone know anything about these tires?
Old Jan 21, 2008 | 09:31 PM
tinman143's Avatar
never had first hand experience with the T1S but it seems like they are inferior to the T1R. Type "Toyo T1S" in the search box and you'll see some results. Typing "T1S" alone will not work. happy hunting
Old Jan 21, 2008 | 09:51 PM
patman530's Avatar
T1R is the replacement to the T1S and it is superior to T1S in all performance aspects and treadlife.
Old Jan 21, 2008 | 10:21 PM
redlude97's Avatar
Not true, the t1s's had stiffer sidewalls, probably the biggest complaint about the t1r
Old Jan 22, 2008 | 11:09 AM
JessNherG's Avatar
Are the T1S cheaper than the T1R's?
Old Jan 22, 2008 | 10:20 PM
Beebo's Avatar
i wouldnt buy any Toyo tire
Old Jan 23, 2008 | 05:14 PM
Q45tech's Avatar
Having visited the ultra modern brand new Toyo facility in North West Georgia and analysed the process and quality control, they currently have the most modern facility in the World. Very few humans to mess up the tire assembly process...........robots work 24 hours per day 7 days per week, no breaks between mainteance cycles.
Only Michelin has the approximate equivalent just more humans to get in the way.
However you must make sure the model they make is the proper tire for you vehicle.
http://www.expansionmanagement.com/s...rticleid=18753
jilljann1
Jul 21, 2020 08:12 AM
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
Jiggerjuice
Aug 31, 2015 11:49 AM
