new wheel offset...
Old Jan 23, 2008 | 09:14 PM
jmtbkr's Avatar
new wheel offset...
I am trashing my stock 17"s on my 03 sedan. They are shot...
I want to replace them with Rial Nogaros 17x8 w/40mm offset.
Is this the correct offset? thanks!
Old Jan 23, 2008 | 09:45 PM
G35sedan03's Avatar
yes that will fit ok, the rear wont be flush but it will fit.
Old Jan 24, 2008 | 06:35 AM
jmtbkr's Avatar
what do you mean by flush?
what is the correct offset I should get? The wheels are on Tirerack's website abd it says 0 offset. I called and they said it should be 40mm.
Old Jan 24, 2008 | 09:06 AM
FlyingLumpia's Avatar
What he means it wont be flush with the fender, they will be tucked in a bit.
Are you planning to lower it, or just keep it normal stance.
Old Jan 24, 2008 | 12:10 PM
jmtbkr's Avatar
Normal stance. I am running 225/55-17 Turanza LSV's. they don't fit flush now, the normal stance IS tucked in, right?
The normal offset is 45mm? should I specify a 45mm offset?
Old Jan 24, 2008 | 12:56 PM
az1anbeethoven's Avatar
u will be fine running a +40mm offset
Old Jan 24, 2008 | 01:54 PM
redlude97's Avatar
I would personally aim for +30 for that width of wheel on a sedan
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
