Help about rims sizes?
Old Feb 14, 2008 | 09:22 AM
specialist's Avatar
2003 g35 couple 18 inches
problem: I have 225 45 18 all the way around the car? Is that bad? Are the rims all the same size? I am running winter tires.
I know that the stock tires size are.
Original Equipment Front Size: 225/45-18
Original Equipment Rear Size: 245/45-18
I thought that it was just the tires sizes that are different not the rim?
I know i should put 245 45 18 but i think 225 45 18 would be better in the snow b/c it is skinner with 20 cm of snow in the ground.
Old Feb 14, 2008 | 09:42 AM
gto2050's Avatar
It won't hurt anything or make anything work funny. The only difference between the front and rear rim is the removable bolt on the hub to keep you from rotating tires from front to rear. They are both either 18X8.0 or 8.5, I don't remember.
The narrow tires is better in the snow.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
