Those using spacers.......
Old Feb 21, 2008 | 12:46 AM
08G37TX's Avatar
Joker, what size tires are you running on your wheels?
Old Feb 21, 2008 | 12:54 AM
JOKER's Avatar
CLUB MODERATOR
245/30/19 front and 255/40/19 rear
Old Feb 21, 2008 | 12:58 AM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Sportcoupe35
But you're not going to want to use the rubber that the M sport wheels come with. They are 245/45/19s all around. The coupe likes a staggered setup. Get a set of wheels, without tires, and then get a staggered setup on your tires...something like 235/35/19 fronts and 255/35/19 rears or something.
Keep in mind, you need to get TPMS too or you'll have that little light on all the time.
I don't
I sold my TPMS with coupe wheels and running this without sensors.
I only get a light on when I drive for more then an hour or so none stop. And then I just pull over shut car off, turn it back on and it's gone.
And as far as tires. I bought them with 245/30/19 and 245/40/19. It ran ok. No traction lights or anything went on.
When I killed the rubber on the back I went with 255/40/19 A little hight on the sidewall but I like it.
It prevents me from taking corners at the hight speed (100 and up) but I like the look of rear tire fatter then front.
Plus it makes car sit lower.
