A/S Tires for the Coupe
Old Feb 27, 2008 | 10:53 AM
CalgaryG's Avatar
Hi all,
I've been looking around trying to find some A/S tires that I can use on my G, with some difficulty...
I have a 2005 G35 Coupe, 6MT. Will these tires fit? (All the way around, front & rear. There are no other sizes available to make a staggered arrangement).
235/35R19 87V
Old Feb 27, 2008 | 10:55 AM
MIA BlazinVQ's Avatar
brb getting cut
they'll fit.
Old Feb 27, 2008 | 06:05 PM
CalgaryG's Avatar
I was also able to find some others on tirerack....Goodyear F1 A/S's in the following sizes:
235/35ZR19
245/35ZR19
255/35ZR19
Could I use the 235's in the front and 245's in the rear? (Or use the 255 in the rear as a tire calculator I found says this will make the speedo read closer to the actual speed)
Would this setup be better as it keeps the staggered fitment? Or should I go the same size all around then I could rotate my tires...
Old Feb 28, 2008 | 06:29 PM
CalgaryG's Avatar
Any advice as to which sizes I should use for the staggered arrangement?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
brian_z
Jul 29, 2015 05:08 PM
