wheel offset
Old Mar 8, 2008 | 12:13 PM
06platinumg35's Avatar
wheel offset
i have done plenty of searches and can not come up with an answer i want to get 19's or 20"s mrr gt1 wheels on my 06 g35 sedan 19/8.5f and 19/9.5r or 20/8.5f 20/8.5r what offset should i be running without having to roll my fenders? i am planning on dropping the car on eibach prokit tires i planned on using are 235/40/19f 265/35/19r or 235/35/20f 235/35/20r any help would be greatly appreciated.
Old Mar 9, 2008 | 07:35 PM
anyone?
Old Mar 9, 2008 | 08:04 PM
Andy2434's Avatar
Originally Posted by 06platinumg35
anyone?
Sorry, I am not familiar with the sedan wheel offsets.
Many of the members, whom may be able to help you, might be away/busy this weekend. I am sure that someone will afford you the answer you are looking for, soon.
Old Mar 9, 2008 | 10:12 PM
FlyingLumpia's Avatar
Q - What size wheels does my stock sedan have?
17" 5 spoke (03-04 Sport)
Front & Rear: 17"x7" (+45mm) (5x4.5 or 5x114.3) bolt pattern
17" 7 spoke (Sedan std)
18" 5 split spoke (05+ Sedan optional)
Front & Rear: 18"x7.5" (+45mm)
Q- What size wheels will fit on my sedan?
The most common upgrade is to 19" or 20" wheels.
You can run the same size all around or staggered where the rears are wider.
(*Caution - the sizes listed below are estimates and may still rub depending on camber and height of your car)
(*Caution - it is not good for the AWD system in the X model sedan to run staggered wheels unless you remove the AWD fuse)
For the same size, an 8.5" +35-40mm rim will fit all around.
For staggered the rear size can be up to a 9.5" +45mm before modification is required. You can run a 10" but it will need to be higher offset to clear the inner fender.
Many people shave or roll their rear fenders in order to fit a lower offset or wider wheel. With the rear fenders rolled you can fit a 10" +40mm wheel with a 275 tire and -.5 degrees of camber or more.
You can go with lower offsets and/or wider wheels if you add in more negative camber and run smaller tires but do this knowing you will wear out the tires faster.
Q - Will coupe 19's fit an 03-06 sedan?
Yes, however, if you lower your car you will need to either run smaller than OEM tires or roll/shave your fenders to avoid rubbing in the rear due the coupe 19's lower offset.
Q - What size tires?
The most common size tires for 19" wheels are 245/35/19 (8.5" rim) and 275/30/19 (9.5-10" rim)
The most common size tires for 20" wheels are 245/35/20 for (8.5" rim) and 275/30/20 (9.5-10" rim)
Please see the wheel/tire section for more information.
Wheel/Tire Link
obender66
18 Inch
Mar 13, 2016 12:20 PM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
