Can the rear wheel of a sports coupe...
Can the rear wheel of a sports coupe be used as a a front wheel?
My front wheel is pretty scratched up and I'm looking for a new wheel...someone has one that they are selling but it is for the rear.
Can I used it for my front?
It is a 18" G35 sports coupe rim
2004 Ivory Pearl Sports Coupe
Re: Can the rear wheel of a sports coupe...
My answer is a maybe. You should be able to use it, since the specs are identical. Width, offset and etc. However if it will work, and I believe it will, with the the correct size tire. You'll need to remove the front bolt that goes into the rotor that prevents you from using the rear wheels on the front. (tire issue, not wheel). Let us know.
Lou
Lou
Since the G35 uses a staggered tire setup from the factory, they put the bolt there as a precautionary that people do not mixup the front/rears. It's not ideal to have a wider wheel/tire setup combo in the front of a RWD vehicle.
Jason Siu
G35STUFF!
Got a Coupe?
jasonsiu.net
Jason Siu
G35STUFF!
Got a Coupe?
jasonsiu.net
dont do it... if your going to put the rear wheel in the front... change both front wheels. You want the same wheels and tires that share the same axel. I would say ur handling and alignment would be thrown off.
that little screw is lame.... take that crap off. Had to take them off to install my wheels.
exhuast, intake, Clear Bra, Race pedals, momo ****, Eibach Sway Bars & Springs, Piaa 4150k, 15% tint, Bronze Volks CE28N 19" 245/275-30,
Custom Leather Interior
Guest
Posts: n/a
You can swap wheels from the rear to the front. All 4 wheels are the same size and offset: 18x8.0 with 30mm offset. Since the tires are staggered, you will need to have the tires dismounted and remounted to be switched ($$$). You might as well have them flipped from side to side at the same time since it won't add in anymore cost.
If you have another car or don't mind riding on the spare for a day of two, ou can get the wheel refinished. You just need to take it to a place like Wheels America. They charge $90-115 to refinish a wheel.
04' G35 Coupe 6-sp
Diamond Graphite/Willow w/Premium
04' G35 Coupe 6-sp
rezendvous420
May 31, 2020 01:26 PM
