Tires?
Old Apr 1, 2004 | 10:55 AM
B1ackmarket's Avatar
Tires?
I am planning on getting a set of 19x8.5, 9.5 with an offset of 40 in the front and 45 in the back for my 5at coupe, what size tires should I go for?
Old Apr 1, 2004 | 12:20 PM
khsonic03's Avatar
Re: Tires?
I don't have a coupe, but those ofsets do not sound good, those would better fit a sedan. I don't even think they will clear the brembos.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways, Borla
Old Apr 1, 2004 | 02:17 PM
Chops1's Avatar
Re: Tires?
I have 245/35/19's front and 275/35/19's rear.
They look just right for that width, anything wider and it looks balloonish, and I don't care for the sucked in look of a smaller width.
You might could get away with a 285. I tried a 295 and that was way too much.
My $0.02
chops's Avatar
Re: Tires?
My $0.02
Old Apr 1, 2004 | 08:36 PM
GoSooners's Avatar
Re: Tires?
You need an offset of about 25 front and 30 rear.
Black on Black 5AT Coupe, Navi
Axis Milanos 19x8.5 F 19x9.5 R
Toyo T1S 255/35 F 275/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Apr 1, 2004 | 09:12 PM
lowrider's Avatar
Re: Tires?
Both Chops and GoSooners are correct on tire sizes and offsets. You are correct on the wheell widths.
Front should be 19x8.5", +25mm offset with a 245/35/19 tire
Rear should be 19.9.5", +30mm offset with a 275/35/19 tire
If you want 19s
I happen to like the look and versatility of 18s however.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
