Will this rub? G35 coupe
Old Apr 4, 2008 | 10:41 PM
M_1313's Avatar
Question Will this rub? G35 coupe
Hi,
I'm planning on buying some new rims.
I would like to get this:
Front: 19x8.5, offset:+15, tires:255/35/19
Back: 19x9.5, offset:+20, tires:275/35/19
According to a tire calculator, the front will stick out 23mm more then OEM and the back 28mm more than OEM.
The suspension is stock and i'm not planning droping the car.
Do you think this setup will rub?
If yes, what are my option for not having any rubbing?
I heard about fender rolling. What is it exactly and how much does it cost?
Thanks guys
Old Apr 4, 2008 | 10:46 PM
amoreno35's Avatar
no your ok.. if you want you can still drop it and it wont rub... i had 20s with the same offset with the s-tech and i did fine
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Soumilg
Jul 18, 2015 12:33 PM
