Another Offset Questions From Yours Truely
Old Jun 4, 2008 | 10:19 AM
G35SHAWN's Avatar
Hey guys am i bit confused about this specific offset therefore i need your feedback. Which is +18 offset on the front & rear what are the chances of rubbing with the fenders...Hope that make sence
Old Jun 4, 2008 | 10:23 AM
AboostedG's Avatar
Grammar FTL
Old Jun 4, 2008 | 11:04 AM
dream_G35's Avatar
depending on how wide the wheel is and tire size, most likely not.
My rear is +17 19x10.5 with 285 tires and they DO rub. Use a 275 and it DOESNT rub. You should be fine
Old Jun 4, 2008 | 07:57 PM
G35SHAWN's Avatar
Thanks Jose.
I am just wondering if it's gonna be a problem with +18 offset in the front.
Old Jun 4, 2008 | 09:34 PM
SteveBlake's Avatar
Originally Posted by G35SHAWN
Thanks Jose.
I have a +17 with a 9.5 width in the front and it rubbed a little but i just cut out some of the plastic of the wheel well, but im also runnin 20's with a 255 tire in the front
Old Jun 4, 2008 | 09:37 PM
G35SHAWN's Avatar
I will be also running 20's once again but 245 in the front.
Old Jun 5, 2008 | 03:43 AM
Mr Inkredibul's Avatar
^ How damn wide is your wheel, what size tires will you be running, and what are you lowered on. Answer these questions and maybe we can help you.
Telling us you are running 20's with +18 offset is like telling us you weigh 200 lb and asking if you are overweight.... It's not enough info.
Old Jun 5, 2008 | 03:59 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
20x9.5 +18 with a 245 tire up front will NOT rub at your current ride height.
-GP-
Old Jun 5, 2008 | 04:03 AM
^ Now I am confused how did you know the OP's wheel width and drop height?
Old Jun 5, 2008 | 04:16 AM
because i've seen hundreds of pictures of his car and i know how low it is. And there's a 90% chance that he's running a 9.5" wide wheel up front. You rarely see 8.5 or 10" fronts on coupes.
-GP-
Old Jun 5, 2008 | 04:17 AM
Ah gotcha.
Old Jun 5, 2008 | 04:20 AM
Ah gotcha.
oh yeah, and you can look in the 'aggressive offset' thread and see how many times i've posted
-GP-
Old Jun 5, 2008 | 07:27 AM
G35SHAWN's Avatar
-GP-
Thanks buddy appreciated.
Old Jun 5, 2008 | 04:56 PM
SIN3's Avatar
Thanks Jose.
+7 up front on 245.35.19 no rubbing no issues car is prob one of the lowest on here.
Old Jun 6, 2008 | 01:37 AM
xcessiveskllzz's Avatar
Turbo G35 coupe single turbo with some goodies
will a 18x10.5 with 275/35 +15tires in the rear touch? and 18x9.5 front 245/40 +15 touch? any recommendations?
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
