offset question
Old Jun 21, 2008 | 03:49 PM
gtrefever's Avatar
offset question
whats the lowest offset do you guys perfer on a gsedan i've seen someone with 18s with +20 offset, would 25 be good with a drop and neg camber.
Old Jun 23, 2008 | 12:25 AM
my05g35sedan's Avatar
Sure if you are snoop dog and want a hoopdie mobile but it'll rub no matter what camber you dial in.
Old Jun 23, 2008 | 12:45 AM
FlyingLumpia's Avatar
It depend on the tire you select. I had a 18 coupe wheel on and with my 10mm spacer on the front and I still had room for more. But that is with a 225/45. So if you could run 225/45 all around and put a 10mm in the rear and be good.
Old Jun 23, 2008 | 11:52 PM
This IS about a sedan right?
Old Jun 24, 2008 | 09:44 AM
Yes
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
