Aggressive offset recommendations
Old Jul 8, 2008 | 01:13 PM
Rphillips6487's Avatar
Ive been debating and debating what offsets to go with my my coupe and now I want to see what all of you recommend
(1) if Im looking at the Volk LE37T at 19x10//19x11 what agressive offsets would you guys recommend?
(2) also..would I be able to get away with 19x10.5 in the front instead of 19x10?
--Keep in mind I have 10mm fenders in the front
Old Jul 8, 2008 | 01:42 PM
waijai's Avatar
i.love.gold
LE37T's are discontinued
Old Jul 8, 2008 | 02:39 PM
I know..I forgot to mention I have someone helping me out to get me a set although discontinued
Old Jul 8, 2008 | 02:51 PM
Cost a G's Avatar
so your front fenders are widened an extra 10 mm?
Old Jul 8, 2008 | 03:06 PM
waijai's Avatar
i.love.gold
-10 to +0 front
+5 to +10 rear
Old Jul 8, 2008 | 03:57 PM
redlude97's Avatar
le37's don't come in those widths
Old Jul 9, 2008 | 01:39 AM
^^what would u recomend then?
Old Jul 9, 2008 | 01:54 AM
redlude97's Avatar
they only come in 9.5/10.5. +12's all around would be good
Old Jul 9, 2008 | 06:43 PM
SIN3's Avatar
here is the questions you need to ask your self
do i care to run small tires?
does my area permit me running small tires?
do i care about shorter tire life?
do i mind if it rubs?
if you dont mind then go with a 9.5/10.5 like redlude stated. that is the widest you can run. Now for offsets +12 is the most "standard" you can get with out using spacers. I ran a +7 on a TE37 by using spacers and it fit fine. (check out aggressive tire thread in this form). read through those posts and see what you like and what you dont like. "flushness" is allways sexy you just have to decide how far you want to go and how much you are willing to sacrfice for it. good luck.
Old Jul 10, 2008 | 03:10 AM
^thanks
Old Jul 10, 2008 | 07:10 PM
irnotfob's Avatar
Also depends on how low you drop your car and how much camber you want to run. It all factors in to the final look.
Old Jul 13, 2008 | 09:40 AM
Triple8Sol's Avatar
As an alternative, you could try to run 10.5 all around, but +22 offset front and +12 ofset rear.
Picture Share
Feb 4, 2018 12:41 PM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
TurTLe*
Sep 29, 2015 01:43 PM
