G35X tire pressures for autoX?
I searched around some and couldn't find this info. If anyone else is running their X at autoX, can you recommend good tire pressures to run? I'm running with Sumitomo UHP summer tires currently. Totally stock otherwise. Just attended my 3rd event this past weekend. I keep playing with the pressures, but I don't think I've found the sweet spot yet.
Some folks say go lower, others say go higher. Towards the end of the day, I tried going 1 lb lower in the front than in the rear to attempt adding a bit of oversteer (or at least less understeer). Fronts were 39 and rears 40 psi. Thing is, I still haven't even worn off the little feelers on the sides of the tread, so maybe I should go softer. I have no idea. So looking for suggestions of those with experience.
So far at these events, I've been the only Infiniti.
Jiggerjuice
Aug 17, 2015 08:41 AM
joedaddy1
Jul 28, 2015 02:58 PM
