Is loosing 2psi a month on my new 20s normal???
Old Jul 18, 2008 | 07:21 PM
mpapers's Avatar
Is loosing 2psi a month on my new 20s Sevas normal???
Hey guys,
I recently put on 20" sevas with yokohama s drives and im consistently loosing about 2psi in all four tires per month. Is this normal? I have check to make sure i have no nails or anything. I run 37psi in the rear and 39psi in the front.
Old Jul 18, 2008 | 07:42 PM
SIN3's Avatar
small leakage is normal could be a fault in the wheel. if it gets excessive then be concerned. i would mention to who ever put the tire on so in case it does get excessive you can go back and they wont shift the blame on you. good luck
Old Jul 18, 2008 | 07:44 PM
GEE35FX's Avatar
Small leakage is not normal.
The only variance you will have in air pressure will be caused by temperature, but your tires absolutely should not be losing air pressure.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
zcherub
Aug 30, 2015 05:04 PM
Phenomenon9
Aug 9, 2015 01:34 AM
