Spacers on factory wheels
Old Jul 24, 2008 | 03:43 PM
dmitriylm's Avatar
My car is getting its 350z S-Tech springs installed on Saturday and I was wondering if anyone has installed spacers on the factory 17's just to push them further out to the edges? Since the aftermarket wheel set from my300zx is too wide to fit the G sedan I'll be sticking with factory wheels for a little while longer.
Old Jul 24, 2008 | 04:01 PM
g35freak86's Avatar
yup it can be done. I've seen it on a sedan on here somewhere, I forget where I saw it, but if I come across it I'll post back here
Old Jul 24, 2008 | 04:45 PM
G35Papa's Avatar
I have 20mm all the way around on my OEM 18s if you want to see them. I'm also dropped more than your S-tech drop will be +rolled fenders in the rear.
Old Jul 24, 2008 | 05:04 PM
dmitriylm's Avatar
So with the S Tech drop and factory 17's can I run 20mm all around without rubbing or will I need to roll fenders as well?
Old Jul 24, 2008 | 06:05 PM
g35freak86's Avatar
you MAY need to roll the fenders since you'll be on s techs. I would just incase anyway
Old Jul 24, 2008 | 08:11 PM
G35Papa's Avatar
I think you will clear but it will be close.
Here is what an 18"x7.5" rim with 20mm spacers looks like. So, you will be 1/2" in more which should clear your un-rolled fender
I know the pics are kind of dark. I can take better snaps if you need it
Old Jul 24, 2008 | 09:00 PM
Da_ReD_G's Avatar
dont have an recent pics but got 25mm on oem 18s and still got a finger gap between tire and fender..do it it will look flush with a drop
Old Jul 25, 2008 | 02:45 AM
dmitriylm's Avatar
Whats my limit as far as spacers go on the 17's then? I want to push these things out as far as possible. Will 25mm work or would that be pushing it?
Old Jul 25, 2008 | 03:05 AM
SteveBlake's Avatar
25mm or bigger
jsimonk
Dec 22, 2023 03:49 PM
tphan
Aug 31, 2015 10:45 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
