H&R 20mm spacer install
Old Jul 29, 2008 | 10:14 AM
theGster's Avatar
i was trying to install my 20mm spacer. i noticed the bolts can't slide through my hub. seems like i have to take this off, but i do not want to risk damaging the bearings. any other way?
Old Jul 29, 2008 | 12:14 PM
redlude97's Avatar
I'm not sure what you are saying, are you trying to install the longer studs after removing the rotor and you can't wedge them in? There should be an opening and you just rotate the hub around until the hole lines up with that opening, and then slide the new stud through.
Old Jul 29, 2008 | 12:17 PM
theGster's Avatar
oppps forgot to mention the studs, but that is what i mean. i will try that. thanks
Old Oct 18, 2008 | 03:52 AM
imjackiechan's Avatar
i cant get my one of my rear screws that hold the caliper in to budge even a little bit. and i dont want to over do it cus that might lead to the nut becoming impossible to remove.
i just got the 20mm hr trak wheel spacers today. and i FAILED so hard. im takng it down to a shop today in the morning so i can get them installed.
im so pissed off right now.
jsimonk
Dec 22, 2023 03:49 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
