Little help with what rim size to get
Old Aug 3, 2008 | 12:33 AM
Still2Slow's Avatar
I'm going to get some work varianza t1s for my 03 coupe, but I don't know what size I should get. Should I go with 19s or 20s? I'm leaning more tomward the 19's. I have brembos so I'm not sure about my offsets. Would this be ok?
19x9 - front +30mm offset
19x10 -rear +30mm offset
My car is stock suspension and it will stay that way. I will also be installing a ST kit in the near future and it would be good to have some traction in 1st - 3rd gears. Should I go wider than 10s in the back?
Thanks
Old Aug 4, 2008 | 08:02 AM
idrive_MD's Avatar
the widths/size are fine, the offsets IMO are a little shallow, maybe something closer to 20mm would be better.
i have 18's with a 25 offset and its still a little inward on the same widths.
Old Aug 4, 2008 | 10:00 AM
acr's Avatar
acr
19s will give you a little more sidewall than 20s, so the ride will be smoother
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
