Winter Tire and Wheel set
Old Aug 25, 2008 | 10:16 PM
MS6_to_G35x's Avatar
Hi Guys,
My first post to the forum. I just replaced my 06 Mazdaspeed 6 with an O6 G35X.
I have a set of winter tires and rim that I used with my speed6.
Wheel: Kazera 17x7. I am not sure but I believe the offset is + 50.
Tires: Dunlop Graspics DS2's 215/50 R17.
Do you guys think they will work on this car? I am concerned about the offset and the difference in overall diameter due to the lower profile especially since this is an AWD vehicle. The tires have just seen 2 Michigan winters and have a lot of life in them and don't want to loose money.
Thanks,
Old Aug 25, 2008 | 11:23 PM
acr's Avatar
acr
The tire size and offsets are all wrong. You'll just have to sell those wheels and buy another set of OEM wheels and some winter tires
Old Aug 26, 2008 | 12:31 AM
GF-4D-G35's Avatar
What is the lug pattern, if it is the same just toss them on? I think if all 4 tires are the same size you will be fine.
I don't think that they will look very good though.
Old Aug 26, 2008 | 09:36 AM
acr's Avatar
acr
Tires of that size will throw off the speedo by 3.2% but I suppose you could use them. Bolt pattern is 5x114.3 for both cars. The offset is too high but that would probably work too, as long as it doesn't rub on the inside. You might have to put on 5mm or 10mm spacers.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
multimut
Canada
Jul 26, 2015 08:43 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
