Wheel Offset Calculation Verification
Old Aug 27, 2008 | 12:45 PM
SuperShick's Avatar
Hey guys......I've got PIAAs 19x9 +25 / 19x10 +25
I wanted to mimic the wheel flushness with the fender like a 19x9.5+22 / 19x10.5+22 so I decided to make these calculations.
Can you verify that my calculations are right. I assumed that the 19x9.5/10.5 are in inches so I converted everything to mm because I know offsets are in mm.
My conclusions show that I need 10mm spacers all-around to get the same flushness as say a Volk LE-37 TA.
Can someone verify this for me? Thanks guys!!
Figure shown below:
<a href="http://picasaweb.google.com/ChristopherD.Lee/RandomStuff02/photo?authkey=UtO4Zfm2PVM#5239239424817119586"><im g src="http://lh3.ggpht.com/ChristopherD.Lee/SLWEf4lyQWI/AAAAAAAAAes/Fz2dW46d5G0/s800/wheel_offset.png" /></a>
Old Aug 27, 2008 | 12:51 PM
redlude97's Avatar
10mm is correct(actually 9mm) Should look good. I've seen people run 15mm all around on the piaa's and rolled fender, better option IMO
Old Aug 27, 2008 | 12:58 PM
SuperShick's Avatar
right on....thanks for the verification red. appreciate it.
15mm all-around?
what spacers would you suggest? ichiba? H&R is it? kics?
Old Aug 27, 2008 | 01:00 PM
redlude97's Avatar
do the piaa's have recessed areas on the backside of the wheel to accept the extra length of a bolt on spacer? I'm pretty sure they do. Or do you need spacers that use replacement extended studs? I would go with Eibach for bolt on, and either eibach or H&R for replaceable stud spacers
obender66
18 Inch
Mar 13, 2016 12:20 PM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
