255's in FRONT?
Old May 12, 2004 | 06:29 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
255's in FRONT?
Hi, I have the opp to get some new tires 255/35/19 MICHELIN PILOT XGT Z4 and 275/30/19 MICHELIN PILOT XGT Z4 for a good price...my question is, what are the disadvantages of running that size tire in the front? I need responses ASAP as I need to make a decision very soon (today).
2 G or NOT 2 G, there is no question!
Old May 12, 2004 | 06:56 PM
jaerian's Avatar
Re: 255's in FRONT?
Why don't you go 455 in the front? So you don't have to turn and just go straight. LOL
'04 G35 Sedan 6 MT DG/DG
'02 BMW M5 13.3 @ 107 (wifey)
'03 Cadillac Escalade
'04 Infiniti QX56 (YEAH!!!)
Old May 12, 2004 | 07:18 PM
a.k.a. RANDYS_G
Re: 255's in FRONT?
Thanks for the humor J. I'm a man in need right now and you're just walking ALL OVER MY FEELINGS! =)
Old May 12, 2004 | 08:00 PM
northface's Avatar
Re: 255's in FRONT?
I guess as long as its not rubbing when u turn you just get more contact...granted i only went up to a 245 in the front and a 275 rear...
Northface
Old May 12, 2004 | 08:02 PM
a.k.a. RANDYS_G
Re: 255's in FRONT?
thanks...I'm sorta looking for ppl that have done it or have first hand knowledge on this...thx again.
Old May 12, 2004 | 08:27 PM
SilverG35C's Avatar
Re: 255's in FRONT?
I haven't done it (just yet) but I have purchased 255/35/20 and 285/30/20 tires for my 20x9.5/20x10.5 wheels that are due in sometime this year
If I beat you to it, I'll let you know how it is.
Jason Siu
G35STUFF!
Got a Coupe?
jasonsiu.net
Old May 12, 2004 | 09:53 PM
SteveAreno's Avatar
Re: 255's in FRONT?
As far as I know there is no downside as long as you dont rub when you go wheel lock to wheel lock. You will get less understeer and steering might be more responsive. Your power steering pump would be working a little harder turning larger tires, so if you are going to do a lot of road racing you might need the bigger power steering cooler.
2004 G35 Coupe 6MT | Obsidian Black/Graphite | Premium | Aero | Splash Guards | XM Radio | Z Tube | JWT Pop Charger | Helix Test Pipes | Unorthodox Crank Pulley | Injen SES
Old May 13, 2004 | 12:28 AM
al503's Avatar
Re: 255's in FRONT?
The 255's should be fine but I have to question the 275/30's in the rear. This will actually have a smaller diameter than the fronts. This might affect your vdc.
Old May 13, 2004 | 02:32 PM
ChicagoX's Avatar
Don't drink and Mag Race
Re: 255's in FRONT?
My experience with running substantially larger than stock tires in front was less than ideal.
The progressive turn-in was traded for a much more abrupt transitional response. In other words, you would turn in, nothing would happen, then all of a sudden, the car would lurch in the direction the wheel was turned.
Steering wheel effort was increased as well, so I assume it would also be putting more strain on your power steering pump.
'04 G35X Graphite/graphite, NAV, wood, premium
Old May 13, 2004 | 03:30 PM
bzabodyn's Avatar
Re: 255's in FRONT?
255/35 front and 275/35 rear is actually the best setup to keep the stagger as close to stock as possible...
2003.5 Brillant Silver G35 coupe 5AT
JDM Clear Corners, Alum. Pedals, Pro-1 Short Ram Intake (Blue Filter), Helix SS Test Pipes, UR Crank Pulley (Red), Custom Grounding Kit (Blue)
Old May 13, 2004 | 03:52 PM
al503's Avatar
Re: 255's in FRONT?
he's looking at 275/30 not 275/35.
Old May 13, 2004 | 04:21 PM
jaerian's Avatar
Re: 255's in FRONT?
Sorry Randy,
But hey, you got your rims though. I would think with that wide of a tire up front, you would not want to lower it. I have 245 in the front and I lowered with tein S-tech I get a slight rub doing a u turn or cornering hard.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
miata007
Aug 17, 2015 04:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
