Help!
Old Sep 6, 2008 | 08:17 AM
GBoy's Avatar
Help!
A few years ago I put on a set of Falken tires on my 03 sedan and man they
were great, after time had passed these tires got real loud and my garage
said you need an alignment which I had done. (worn on the inside) I figured it was my fault as I had a suspension change, I went to a coupe suspension except for the front springs where I installed z springs. Tires went in the garbage and I purchased some new ones in April, but now its happening again. Took it to a garage and they said they can't bring the front into spec, no problem with the back because he can adjust something but for the front he said I would need a camber kit, I have heard of this but I did not know that my car would need one with the changes I did.
Does this make sense, I think he tried to bring to spec with a sedan
Should he be trying to bring into spec with a coupe.
Thanks
GBoy
Old Sep 6, 2008 | 02:57 PM
GBoy's Avatar
Ooops
Wrong place I will post this in the suspension section
