Advantages of larger rear wheel diameter?
Old Sep 24, 2008 | 06:04 PM
05GRide's Avatar
Originally Posted by speedracerg35
i think you should clarify if you mean larger rim w/same overal diameter or larger diameter wheel and tire.
if you mean the latter, your acceleration will suffer on the track, but you will increase gas mileage if you do a lot of highway driving.
This would hold true as long as the new wheel tire combo is not heavier and you are just cruising at constant speed on the highway. A larger diameter usually involves a slightly heavier rim (than the same type of a smaller one) since it's more metal. Plus, you're moving the weight out FURTHER from the center of the rim, which creates more rotating mass. So yes, you are correct that acceleration suffers because it takes more power to get those rims moving and up to speed, which also would decrease gas mileage over the previous set up. However, if you are just looking at cruising speeds, a larger overall diameter would theoretically get better mileage, although it's negligible.
The reason I stuck with 19s on my car and not 20s, was simply because I do 80 miles of traffic-y driving each day and I didn't want acceleration or mileage decreases due to the weight being further from the center of the rim.
Old Sep 24, 2008 | 06:06 PM
Swivel's Avatar
Moderator
Helps with lane changes.
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
