Keeping (VDC) happy
Oct 1, 2008 | 10:37 AM
Quick question, if i run a 235/35/19-front and 275/30/19-rear would this screw with the gear ratio and the vdc.
If so what 19 inch tire size conbo would you recomend.
thanks.
Reply 0
Oct 1, 2008 | 11:34 AM
go 245/35/19 front.
275/30/19 will work in back.
use this tire calculator
http://www.discounttire.com/dtcs/infoTireMath.dos
Reply 0
Oct 1, 2008 | 12:08 PM
or 275/35
cause 30 is a very thin wall, and will leave a very large gap if not lowered, or lowered enought
Reply 0
Oct 1, 2008 | 12:30 PM
275/30/19 is too short to run in the rear, and is actually shorter than a 245/35/19 front. Horrible size to run
Reply 0
Oct 1, 2008 | 01:43 PM
That's what i figured i guess that's why most people run 255/35/ & 285/35 on 19's....
Reply 0
Oct 1, 2008 | 02:40 PM
or 245/35/19 and 275/35/19. Just avoid the 30 series
Reply 0
Oct 2, 2008 | 01:17 PM
Quote: 275/30/19 is too short to run in the rear, and is actually shorter than a 245/35/19 front. Horrible size to run
My bad, that's what I really meant, I promise!
Reply 0
