Tires for 19s
Old May 23, 2004 | 11:37 PM
C_Lawd's Avatar
Tires for 19s
What is the difference in ride quality between 275/30ZR19 and 275/35ZR19 tires on the rear of the G35 coupe?
'04 DG Coupe
Old May 24, 2004 | 11:25 AM
al503's Avatar
Re: Tires for 19s
I've never ridden on 30 series tires before so I can't talk about ride quality. However, I would suggest you go with the 35's for the following reasons:
1. keep the rolling diameter closer to stock and keep the proper stagger between the fronts if you go with 35's up there.
2. more pothole protection.
3. the tires will last longer.
Old May 24, 2004 | 12:33 PM
C_Lawd's Avatar
Re: Tires for 19s
That makes good sense. Thank you for the informative reply.
'04 DG Coupe
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
