where can i get time attack
i just blacked out my rims, and was looking into gettin a time attack. could someone tell me where to buy these, and the website would help as well. thanks. im looking for a red one.
wait... i dont understand.. you just blacked out your rims... and you want to go buy new ones? or are you assuming that "time attack" is something you can do to any black rim?
The timeattack volk rims were a limited run (the black and reds)... i believe some vendors might still carry it... now-a-days the time attack standard is the "honda" time attack which is the white wheels w/ red pin stripe...
Originally Posted by 4drmadness
hey thanks for the quick reply. i have oem 17's. will the 18's time attack fit? they only have 18 and 19's on the website
with 17's you don't have enough time to attack
in all seriousness.....if you use the red viny made for the 18s on your 17s, they will end up on your tires.
Thanks Calvin
The 18" vinly strip might actually work. I had to cut it down a bit to fit my 18's when I did that. It's flexible enough you may just be able to make it work. Only way to know forsure is to try it
NASA has time attack at Buttonwillow next weekend! https://www.nasaproracing.com/ems/event/792
