flush on one side, not so much on the other LOL
Old Nov 24, 2008 | 03:37 PM
Calvin's Avatar
Overglorified Altima
So I noticed my driver side rear SF-Challenge is considerably more flush than the passenger side rear.
Both are 10.5" +23 w/ 275/35 set at -1.5 camber & dropped exactly the same (measured it)
What could it be? LOL
Old Nov 24, 2008 | 04:09 PM
sammy_G's Avatar
a shop told me it was normal.. "all cars are different"
my 03 sedan had the same issue... (off by a few mm)
Old Nov 24, 2008 | 04:24 PM
Calvin's Avatar
But it wasn't like that with my Works.
Old Nov 24, 2008 | 04:33 PM
redlude97's Avatar
switch the rims from side to side to see if you still notice the difference
Old Nov 24, 2008 | 04:35 PM
ShanesG's Avatar
yeah my front wheels don't match either, one side is a lil more flush than the other, like 5mm
Old Nov 24, 2008 | 04:38 PM
jlin615's Avatar
Try tape measure it. Sometimes it's eye illusion of left side and right side.
redlude97's Avatar
BTW, was your alignment set with you sitting in the car? Are you in the car when you notice the difference? That could be why they look different
Old Nov 24, 2008 | 11:43 PM
Calvin's Avatar
^^^i was not in the car during the alignment and i am not in the car when i notice the difference. trunk is empty, car is on level ground. i'll try swapping them over thanksgiving break.
any other ideas?
Old Nov 25, 2008 | 01:25 AM
O HELLA JDM's Avatar
for real...i never really noticed????
Old Nov 25, 2008 | 07:05 AM
Triple8Sol's Avatar
Maybe one is a high disk and one is a low disk. Check the stickers on the inside of the barrels. Or just measure the thickness of the disks.
Old Nov 25, 2008 | 08:25 AM
reverse's Avatar
hondas have that same problem, but in the front.
Old Nov 25, 2008 | 08:48 AM
GreenGoblin's Avatar
The goblin resurrection
Maybe your car was built on a Friday?
Old Nov 25, 2008 | 12:42 PM
Calvin's Avatar
yeh, i checked everything on the stickers to make sure. my first thought was they had different offsets (bought the wheels used) so i checked the stickers asap. everything matches up.
Old Nov 25, 2008 | 12:44 PM
redlude97's Avatar
Were they ever taken apart to be polished? They may have installed one of the front centers on the rear, and vise versa. Ask Triple8sol about that one
Old Nov 25, 2008 | 01:04 PM
Johnmikins's Avatar
Just added rear camber set along with a rear alignment and have same issue. Was told that its how the car is made...you can barely notice it...
