Nismo Question
Old Jun 1, 2004 | 02:09 PM
Catatafish's Avatar
Nismo Question
The Nismo wheels are 18" x 8.5" front, 18" x 9.5" in the rear.
Thus, the diameter is 6.5 MM smaller in front and .5 MM smaller in rear if I use the recommended 245/40 and 275/40s.
1) Will this bother my VDC?
2) What will it do to my speedometer?
3) What are the implications of the wider tires? Will it stick out of my wheel well? Will it create more understeer? etc.
I'm really looking to lose weight at the wheel without creating a cleaning nightmare. What else should I be thinking about in my wheel evaluation? I want performance first, cleaning ease second, not having a retarded looking car third.
I'm also considering the Volk GT-N in a gunmetal. If I go this route, should I stick with the 8" width? What advantage/disadvantage will be achieved going wider, and if I do go Volk GT-N, what offset do I look for in the front and rear?
http://www.revhighonline.com/page.ph...00000000000175
Any thoughts would be appreciated.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5
Old Jun 1, 2004 | 04:35 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Nismo Question
Using the numbers below you're looking at less than a 1% difference in circumference. You won't notice it on your speedo. VDC will be fine as well.
After the tire size is the diameter, then the cirucumference.
225 45 18 25.97 81.55 Coupe 18" (Front)
245 45 18 26.68 83.78 Coupe 18" (Rear)
245 40 18 25.72 80.75
275 40 18 26.66 83.72
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
yoyoyo8
Aug 12, 2015 03:04 AM
Team STILLEN
Aug 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
