04' G35 Coupe 18" OEM Wheel owners....
Old Dec 27, 2008 | 07:36 PM
johnjohn077's Avatar
Hey guys.. need a little help here... I'm getting one of my DPE wheels repaired.. so in the meantime I had to throw my old 18" stockies back on... the problem is when I mounted one on.. there was a 1/2" gap between the hub and back of the oem wheel... is this normal?? i dont recall there ever being a stock spacer... do you guys have the same gap on your 18" stockies?
Old Dec 28, 2008 | 01:52 AM
redlude97's Avatar
most likely the hubcentric ring is still stuck to the hub. Pull the wheel ASAP and remove it. Driving on it can result in snapping off all the studs
Old Jan 2, 2009 | 12:26 AM
slow600's Avatar
The hub pin may also still be on.
bTanz
Oct 15, 2015 02:31 PM
teamghost
Jul 28, 2015 04:52 PM
mushu
Jul 15, 2015 03:55 PM
djreinx
Jul 13, 2015 05:04 PM
