can someone tell about these wheels.
Old Jan 2, 2009 | 08:39 PM
6']['9's Avatar
Please. Ive been searching for some time & cant find anything on these wheels. thanks
Jay
Old Jan 2, 2009 | 08:41 PM
Glex25's Avatar
Administrator
Varianza T1S
Old Jan 2, 2009 | 09:01 PM
O HELLA OEM's Avatar
is it me or does the IP look like the wheels are chopped
Old Jan 2, 2009 | 09:13 PM
6']['9's Avatar
yeah they looked chopped to me as well. the lip in the front is deeper than the lip in the rear. thanks thats what i was needing.
would those be 20's?
Old Jan 2, 2009 | 09:21 PM
EL-EE-ES's Avatar
those are the work t1s...i have a set on order, there is plenty of people on here with them
Old Jan 2, 2009 | 09:43 PM
Glex25's Avatar
Administrator
Old Jan 2, 2009 | 09:48 PM
Texasscout's Avatar
I didn't think I would, but I really like that black roof.
6']['9's Avatar
what size are the ones on the white G? I just did a search and have notices some people run the 19s & some run the 20s but one guy had a blue one and ran a 20/21 combo & this set up this guy has it exactly what im looking for. thanks again.
Old Jan 3, 2009 | 09:27 AM
EL-EE-ES's Avatar
the white one has 20s...i have 19s on order, i seen one or two on here with the 20/21 combo
Old Jan 5, 2009 | 04:01 PM
broke_as_ajoke's Avatar
bro.. i just checked my notes and i replied back, but the rest of the jokers on the site have helped u out already.. they are 20's x 9.5 245 3 0in the front and 20x 11's 285 35 in the rear.. it took me 4 months to get them
Old Jan 5, 2009 | 04:04 PM
redlude97's Avatar
why would you run such a huge tire in the back? 285/30/20 is the correct tire size
Old Jan 5, 2009 | 04:09 PM
cuz that is the only thing i could get on the rim.. 275 is too stretched which results in no side wall. rim would almost be touching the road surface. it's either 35 or 30 i can't recall i would have to look.. Also when i got my car.. my factor tires and rims were staggered but wanted to keep the same ratio so i had the tire guy do the math and my mechanical engineer buddy put the specs in Pro E to give me the right setup with no problems
Old Jan 5, 2009 | 04:14 PM
redlude97's Avatar
A engineering couldn't figure out that a 285/30/20 is the same height as a stock 245/40/19:245/45/18? 285/35/20 is almost an inch taller than stock, the 285/30/20 is still staggered from the front 245/30/20 also. Your staggered ratio now is way off from stock. I'm surprised you aren't having VDC issues
Old Jan 5, 2009 | 04:44 PM
well i have not had any problem with it... car rides fine... no pulling or camber or toe issues at all. "Knock on wood" well my buddy must have knew what he was doing, cuz i don't have no problems with it..
Old Jan 5, 2009 | 04:45 PM
redlude97's Avatar
Except your speedometer/odometer are now significantly off
