350z suspension swap torque values
Old Jun 21, 2004 | 12:15 PM
khsonic03's Avatar
Re: 350z suspension swap torque values
Hotchkis uses poly bushings, and they don't squeak if they are lubed properly. I have them with no issues. What were your final specs?. I am interested to know what your front camber was, as mine was out of spec with the 350z suspension. I am assuming that you are stating that it is "in spec" according to the coupe settings.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old Jun 22, 2004 | 03:59 PM
alfapwr's Avatar
When I brought the car in the left front camber was -1.22 deg. and the right front was -1.05 deg. The allowable specs for both sides is 0.00 to -1.5 degrees. These are the sedan specs as far as I know. The left rear was -1.36 and the right rear was -.76. Allowable range for the rear is -.70 to -.96 deg.
My after alignment camber settings are: LF = -1.25, RF = -1.07, LR = -.75, RR = -.87
Drove the car to Santa Monica for an anniversary overnight. Was a little firm on the 405 where the pavement isn't so good but was nice and smooth back home in the Santa Clarita Valley. But my wife didn't make any comments so all is well as far as I'm concerned !!!
Later,
Dan
Stevenson Ranch, CA
2004 6mt Sedan: Black on Graphite.
Just splash guards and trunk mat - NO OTHER USELESS CRAP !!!
Old Jun 23, 2004 | 11:50 AM
khsonic03's Avatar
Very similar to my values. What was your rear toe with that camber? It seems odd that the left front has more negative camber than the right when lowering with the 350z suspension. Mine was the same way. I was only able to do about 1.0 in the rear in order to keep toe in spec.
Old Jul 8, 2004 | 03:56 PM
3point5SE_Auto's Avatar
andyranck, see search works dude, look at the first few posts here.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Machine Head
Sep 4, 2015 07:22 PM
yassy
Aug 9, 2015 07:31 PM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
