For fender, 275/40/18 +20 = 295/35/18 +30 ???
Old Jan 22, 2009 | 10:11 PM
hyunkoon's Avatar
Hello
I have a question about rubbing with not rolled fender.
If 275/40/18 +20 offset does not rub on stock height and none rolled fender,
295/35/18 +30 offset would not rub neither?
because those +20mm in tire width will be added as 10mm to each side of wheels so
+10mm in offset will counter increase of width of one side.
Am I right? or am I making mistake?
Thanks!
Old Jan 23, 2009 | 09:56 PM
eurodre's Avatar
the +20 "sticks" out more than the +30 does
Old Jan 23, 2009 | 10:02 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
In theory, you are correct. But NOT every tire is made the same. Some have square sidewalls and some have round sidewalls. If you stick withe the same brand/model tire, then it should fit fine.
-GP-
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alexbenz
Sep 26, 2015 11:30 AM
TeamNoSleep
Sep 13, 2015 07:40 PM
