Ichiba V1 or V2 spacers
Old Jan 27, 2009 | 02:31 PM
1SickVeilsideZ's Avatar
No difference in spacers, only if it is hubcentric or not.
V1 spacer is for 5mm and 10mm which you usually don't need to change the studs.
V2 is for 15mm or bigger which already has the studs in them so all you have to do is place it on the hub of the car tighten it down and you can bolt on the wheel without having to replace the entire stud to work with the spacer which is a lot easier IMHO.
Hope that helps.
Terry_G35
Sep 10, 2015 08:17 PM
Boston
Archived Sales
14
Nov 4, 2008 07:39 PM
neight
Archived Sales
Oct 24, 2008 02:41 AM
flyfl1pguy99
Archived Sales
Aug 16, 2007 03:24 PM
