recommendation of tires to get for stock 17"..
Old Feb 4, 2009 | 05:03 PM
jin22gt's Avatar
I need new tires ASAP! I have the stock Goodyear RS-A and it has no treads left on it. I live in New York and we get a good amount of snow. What tires would you guys recommend?
Old Feb 4, 2009 | 07:37 PM
Seymore's Avatar
I prefer dedicated seasonal tires.
In the summer I run Goodyear Eagle F1 GS-D3 225/50s.
In the winter I run Dunlop SP Winter Sport M3 Vs 215/55s.
I've been really pleased with both sets. They perform exactly as I hoped they would.
Old Feb 4, 2009 | 08:22 PM
G35sedan03's Avatar
Nankang M+S for Mud+Snow. decent price and should last you a while depending on how you drive.
Old Feb 4, 2009 | 09:41 PM
jin22gt's Avatar
Im looking for a high performance all season tire. Don't feel like going thru the hassle of buying new tires during the summer.
Hows the Dunlop SP Sport Signature 215-55-17? It seems to have good reviews on tirerack.com for $116.
Any recommendations for high performance all season tire will be great!
also are there any other site with cheap tires that is trustworthy.
thanks
Old Feb 4, 2009 | 09:57 PM
jin22gt's Avatar
just a question. Do we have to replace the tpms? or can we just reuse the old one?
Old Feb 4, 2009 | 10:19 PM
Seymore's Avatar
Every time I swap my tires over they re-use the same TPMS sensors. They replace the wear items though, for about $4 a wheel I think (I'd have to check an invoice), they call it a TPMS rebuild kit I believe.
Can't help you on the performance all-seasons, sorry.
Old Feb 4, 2009 | 11:14 PM
jin22gt's Avatar
while im on the the tire topic, can I get a wider and lower profile tire? there shouldnt be a problem where the tire wouldnt fit the oem rim?
Old Feb 5, 2009 | 12:08 AM
skahide's Avatar
same questions, but how about the Nitto NeoGen?
Old Mar 14, 2009 | 10:26 PM
eagleee's Avatar
Will 235/55 or 245/50 fit on stock 17 inch?
Old Apr 10, 2009 | 02:03 AM
BuckeyeInMI's Avatar
These are the closest to stock.
215/55-17 = 26.3" diameter, 4.65" sidewall, stock size
225/50-17 = 25.8" diameter, 4.43" sidewall, -3.4% circumference
225/55-17 = 26.7" diameter, 4.87" sidewall, +3.3% circumference
235/50-17 = 26.25" diameter, 4.63" sidewall, -0.4% circumference
245/50-17 = 26.6" diameter, 4.82" sidewall, +2.6% circumference
I would not run 235/55-17's, they're just too big.
235/55-17 = 27.2" diameter, 5.1" sidewall, +6.6% circumference
And you might want to be careful with the 245/50's. The stock wheels are 17x7, and this size tire has a fit range of 7-8.5", so it's going to be a bit stuffed on there. But it should work.
jsimonk
Dec 22, 2023 03:49 PM
multimut
Canada
Jul 26, 2015 08:43 PM
realtalk21
Jul 20, 2015 09:07 AM
Soumilg
Jul 18, 2015 12:33 PM
