problem with running 245 font and 285 rear?
will i have a problem with this? my fronts are on back order and i wanted to put the rears on because i have a flat in the rears... what do you guys think?
you will be fine. I run 245/35 in front now and will be going to 285's as long as you dont do a crazy drop you wont have to worry about rubbing....although you might want to consider rolling the fenders if you do lower your car
rezendvous420
May 31, 2020 01:26 PM
