Please Help!
Old Feb 21, 2009 | 05:32 PM
goodmank's Avatar
Please Help!
My question is since the back of the axis mod wheels are flat, can I even install spacers with them and if I can how does it mount flush to the spacer?
This is in regards to spacers; however, I have already determined what sizes I need and I have tried searching houndreds of threads with no luck of finding an answer.
I currently have:
2006 coupe
Sport Tuned Suspension
Axis 7 Mod wheels
Front:
19x8 +45 offset
225/40/19 tires
Rear:
19x8 +45 offset
245/40/19 tires
I just bought 25mm Project Kics spacers with hubcentric rings and I tried installing them; however, when I went to install the spacers the OEM studs stuck out longer than the spacers and therefore would not allow the wheels to mount flush to the spacer.
Thank you to anyone who can help me with this!
Old Feb 21, 2009 | 11:24 PM
goodmank's Avatar
Anyone?
Old Feb 22, 2009 | 06:44 PM
goodmank's Avatar
Bump..
Old Feb 22, 2009 | 08:27 PM
EL-EE-ES's Avatar
if the back of the rim is flat, they wont allow the use of spacers...do you have any pic of the back of the rim
Old Feb 22, 2009 | 09:13 PM
goodmank's Avatar
I don't have one of my wheels but I can get one of a rim that is identical to the back of mine...
Old Feb 22, 2009 | 10:13 PM
EL-EE-ES's Avatar
you cant use spacers with studs in them...your going to have to find spacers without studs and get extended studs on your hubs...im not sure if them make 25mm spacers without studs. i think your better off put the wheels up for sale and getting a different set in better offsets
Old Feb 22, 2009 | 10:39 PM
goodmank's Avatar
yeah, I was afraid of that...
Thanks for the input !! I will definitely be putting these up for sale soon!
