275/35 on OEM Rays... on a Sedan?
I'm looking for some OEM Rays 19s for my 04 sedan. I found a guy that has some locally, but the rears are 275s (I believe 275/35 since that's almost an identical diameter as OEM wheel/tire combo).
Any chance in hell I'm fitting these on my sedan w/o running a lot of camber? I'm guessing i'd have to completely flat-roll my rear fenders, but I'm still not sure I can pull it off. Dropped on unrevised z suspension right now, but have coupe rears in the trunk to install.
Final tally would be 19x8.5 + 33 w/ 275/35/19
Thoughts?
Thoughts?
245-40-19. Decide for yourself. I say not w/o more camber and a fender roll (if that's even enough). If I calculated it right, the outside would stick out 0.6" more than what you see here
joedaddy1
Jul 28, 2015 02:58 PM
