20' tires fitment
Old Mar 8, 2009 | 04:13 PM
manh3's Avatar
20' tires fitment
Hey guys I have a 04 G35 coupe. I only lower the front by 1.1 inch w/ Eibach Springs Pro Kit and stock rear. I am planning to get 20's MSR wheels style 093 in silver.
rims spec:
Front 20x8.5
Rear 20x10
The shop told me that the tires fitment would be Falken 452's: 245/35/20 F and 275/35/20 R. But after reading some posts on the forum about the accuracy of speedometer and odometer readings. It might also cause bearing discrepancy due to the tires size. What is the difference with going 275/30/20 R than going with 275/35/20 R? Exactly what tires size should I get for the front and rear? Any advise is greatly appreciated
Old Mar 8, 2009 | 11:26 PM
Don@TireOption's Avatar
Replied to your email. 245/30-20 & 275/30-20. PM me if you need a quote!
Old Mar 9, 2009 | 12:03 AM
COR Photog's Avatar
Cant you run a 285/25/20?
Old Mar 9, 2009 | 12:31 AM
az1anbeethoven's Avatar
OP, you need to run either a 245/30/20 or a 255/30/20 front and 275/30/20 rear
you should run a 285/30/20 instead
Old Mar 11, 2009 | 02:20 AM
jrozul00's Avatar
falken 452 are nasty go with a set of nitto 555 or Michelin sport proxy. and honestly i would stick with 19 because 20" rims with those low profile tires are bound to be bend or cracked.
Old Mar 11, 2009 | 03:50 AM
redlude97's Avatar
Calling 452's nasty and then recommending NT555's?
Old Mar 12, 2009 | 06:27 PM
yea, i agree with you, OP you should run 17s to just be safe....if your oem are 18s or 19s better trade them in for the 17s...just to take extra protection that they don't bend or crack
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
