Correct tire pressure for oem 19's?
Old Mar 9, 2009 | 04:11 PM
B_Lam's Avatar
Hey guys...this might be a stupid question but my car didn't come with the manual so i don't really know. I've been putting 35 into my oem 19's but today my dad was filling air in all the tires for all the cars...he looked at mine and it said that the max is 50...so he ended up filling all 4 of my tires to 50. Would it be safe for me to drive on 50lbs of air in my tires? Btw i have kumho ecsta tires. Thanks for the help...
Old Mar 9, 2009 | 05:05 PM
Deepdiver's Avatar
the tires can be filled to that pressure, but you want to follow whats recommended by the manufacturer. They take into account load, handling, blah, blah. Infiniti says 35psi front and rear.
Old Mar 9, 2009 | 05:17 PM
Skaterbasist's Avatar
Retired SuperMod
50 is way too much. Stick to 35, which is the recommended pressure for our tires.
Old Mar 9, 2009 | 05:22 PM
scotts04MT6's Avatar
I like the pressure a little higher, in the ~37 range for the rear and 38 front.
Old Mar 9, 2009 | 05:39 PM
tragedycat's Avatar
Just do 35 psi all around, I do that for my stockers as well as aftermarket wheels.
Old Mar 9, 2009 | 05:40 PM
B_Lam's Avatar
Thanks for the info guys! Really appreciate it.
Old Mar 11, 2009 | 02:53 PM
G35fromPA's Avatar
Tire pressure is based on the car weight and weight distribution, and is determined by the car manufacturer, regardless of tire size or make.
Old Mar 11, 2009 | 11:49 PM
TheTick's Avatar
You can honestly tell the difference between 37 and 38 psi in your tires?
Old Mar 12, 2009 | 12:56 AM
Thinkdiesel's Avatar
35, tires wear down best
Old Mar 12, 2009 | 02:26 PM
Compared to 35, absolutely. I like slightly less in the rear to counter oversteer from early throttle.
Old Mar 12, 2009 | 02:52 PM
Mitsuko's Avatar
as a fyi, for future reference too: you don't need a manual for tire pressure. open the drivers door and its on a sticker on the column frame of car. its like this for most modern cars, whether domestic or foreign.
Old Mar 12, 2009 | 10:44 PM
Slvr G35's Avatar
35 psi front & back!!
Old Mar 13, 2009 | 05:14 PM
acr's Avatar
acr
I have coupe 19s on my sedan with 245/30/19s all around. I've been running ~33psi
Old Mar 13, 2009 | 05:38 PM
gary c's Avatar
OMG....50 PSI in your 19" must ride really well?
I've never been able to find out why tire company's put the max psi on the
sidewalls of tires. That's just too confusing to non-car types and will invariably wear out the centers of your tires. I run 37 psi in all my tires front and back, but the manual does recommend 35. Explain this to you Dad and why....
Gary
Old Mar 24, 2009 | 02:59 PM
BostonG6spd's Avatar
do even if we have 20's or if you have 17's 35 is still best?
jsimonk
Dec 22, 2023 03:49 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
joedaddy1
Jul 28, 2015 02:58 PM
